In this post we'll present Naviate Rebar Extension, helping you to automatise the process of generating reinforcement for elements like beams, columns and piles.
Reinforce with Naviate Rebar Extension
To get started, go to Naviate homepage to download and install Naviate Rebar Extension here.
Types of extensions reinforcements
There is features to help you reinforce various categories
- Automatic reinforcement generation
- Beams
- Columns
- Continuous footings
- Parapets
- Pile caps
- Piles
- Retaining walls
- Slab corners
- Slab openings
- Spread footings
- Wall corners
- Walls
There's also a feature for clash detecting
- Interfaces of reinforcing bars
How to reinforce a concrete column - an example
In the example below, we will look into how you can reinforce a concrete column (structural column) with associated foundations (isolated foundation).
Select the items you want to reinforce first, then select the function you want to use. Choose the column, then go to Naviate REX and Columns.
In the left hand menu, the first top part will give you an overview of the column family type, Geometry as well as the Associated geometry.
Next up is Bars and Stirrups to make sure you fill in the reinforcement. The dimensions shown on the right-hand side will help you understand how to fill in the values correctly.
In our example we un-select Dowels and Stirrups for dowels in the dowels menu, before confirming with OK.
We then reinforce the foundation in the menu under Naviate REX and Spread Footings.
For our example we use the placement in Bottom bars and Dowels and un-select Top bars and Stirrups in the pier. Then we confirm with OK.
The reinforcement is now generated.
To adjust the reinforcement in one of the elements, select the element and run the function again.
Do you have other topics you would like us to go through? Let us know in the comments below and we'll get back to you!
